CMS Meeting App WebRTC - selfview doesn't have a pin to disable auto-hiding
Does anyone have this problem? There must be a pin for self-view according to the User Guide and on-screen help, but I don't have one and I cannot find where it is configurable. Kind of a small problem, but it is important as it reminds that you are on video so you don't do silly things =)
Thanks!
Thanks Dmitry.  The doc should be updated soon to remove the selfview pin for webapp to since its not supported.  The help button on the app may require another change to have it removed.  Sorry for the confusion here.
VR
Patrick Pettit
Patrick Pettit
I don't believe web client 2 ever had the option to pin the selfview like the thick client does.  From what I know, this may be doable in web client 3, which is the next iteration of the client.  I'll have to look at our docs to see what it says about this for the web app, but just logging in and joining a call, I don't see a way to pin the selfview.  Hope this helps answer your question.
VR
P2
It is clearly stated in the Cisco Meeting App WebRTC User guide:
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingApps/User_Guide/Cisco_Meeting_App_WebRTC_User_Guide.pdf
Also, it is listed if you click at the on-screen help button in the WebRTC client. So I suppose it must be supported.
Thanks!
VR
Patrick Pettit
Recognize Your Peers
