05-10-2018 09:28 AM - edited 03-18-2019 02:05 PM
implementation going on.
One CMS 1000 = one CMS VM (callbridge, xmpp, webbridge,webadmin)
ONE CMS recorder = One CMS VM (only recorder)
on CMS VM, applied cms.lic.
now how will I apply license for RECORDER VM? what MAC address need to choose? recorder VM MAC address? recorder license we need to apply in CMS VM where callbridge is reside. but already there is cms. lic applied. again one more cms.lic? if i do will it not overwrite the previous cms. lic?
what name i need to put of recorder license?
can we give any name of .lic file or not?
if i need to select the MAC address of REcorder CMS VM, then i mistakenly created license with MAC address of callbridge VM(that was the one I created first.)? how will i change it MAC address of recorder VM?
certificates all are self signed right now. is it a must them change to internal CA based certificate.
callbridge = callbridge-self.key, callbridge-self.crt
xmpp = xmpp-self.key, xmpp-self.crt
webbridge = webbridge-self.key, webbridge-self.crt
webadmin = webadmin-self.key, webadmin-self.crt
recorder = recorder-self.key, recorder-self.crt
Solved! Go to Solution.
05-10-2018 11:08 AM
05-10-2018 10:01 AM - edited 05-10-2018 10:03 AM
The license is applied against the call bridge that will connect to the recorder and not the actual server hosting the recorder VM. Check the CMS Deployment guide -
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Installation/Cisco-Meeting-Server-Deployment-Planning-and-Preparation-Guide.pdf
Edit : When you claim the PAK/get your license issued, the license file should have all the features that you paid for. If you have a new cms.lic file you can upload it to the call bridge. The previous one will be overwritten.
05-10-2018 11:02 AM
05-10-2018 11:08 AM
05-10-2018 11:10 AM - edited 05-10-2018 11:11 AM
im not in the implementation site now. but i can tell what it was showing there.
the result shows 4 activated. the last one is recording.
05-10-2018 11:18 AM
05-10-2018 11:45 AM
05-11-2018 07:27 AM - edited 05-12-2018 09:20 AM
Im getting callbridge api error as 400.
https://ipaddress:445/api/V1/callProfiles/
when i do GET operation using postman chrome, it gives 400 bad request error. bad syntax it mentions. where is this bad syntax im not understanding it.
05-15-2018 09:12 AM
08-30-2018 05:58 AM - edited 08-30-2018 06:01 AM
Hi guys,
We have 3 CMS1K as call bridge cluster and they have CMS recording option.
We planning to install CMS Recorder node into BE6K.
CMS Recorder node needs any software license ?
Baris.
08-31-2018 05:31 AM
09-01-2018 03:55 AM
Thanks Nipun,
That what I need to hear. Thank you confirming.
Baris.
