CMS Server with ISDN
sabir.bedi1
Team
Please help me understanding if i still need external ISDN Gateway for ISDN Video link calling  using the CMS ?
Or CMS has inherit feature of supporting this ?
regards
sabir
Youssef Aoufi
Level 3
Level 3
Hi guys,
Can we connect CMS to an isdn gateway?
3241 isdn gateway is EOS , which alternative do we have?
CMS does not support ISDN.  To make ISDN calls, you need a gateway
The ISDN GW 3241 is the latest gateway available, there is no ISDN alternative (other than endpoint-based ISDN link), the recommendation is to move to SIP based solutions such as Expressway.
Ammar Saood
simple answer is. Check CMS datasheet and if it supports ISDN protocol then it will work otherwise you need a gateway to translate ISDN calls to SIP calls.
to my knowledge it does not support direct termination of ISDN calls.
AMMAR SAOOD
Please rate and mark answered if helpful
