CMS WEB BRANDING 2.9.2
Chet Cronin
Level 4
Level 4
Can someone send the link to download the web_branding.zip file that is for the CMS 2.9.2 ??
Thank you.
Chet Cronin
2 Accepted Solutions
Sateesh Katukam
The file name should be "sign_in_settings.json". your extension is showing as ".jason"
when you extract web_branding.zip file it should directly extract to files (not to a folder)
6 Replies 6
Chet Cronin
Level 4
Level 4
I see the code but still not changing the text below the logo in the web_branding.
Below is what I uploaded to the CMS but the text still isn't changing ...
I used Notepad ++ and saved the file as .jason
"browserTabLabel" : "USACE Meeting App",
"panelLabel" : "USACE Meeting App",
"allowClient" : "true",
"allowWebRTC" : "true"
Still show Cisco Meeting App under the logo. ???
Any ideas ??
Chet Cronin
Sateesh Katukam
As @Sateesh Katukam mentioned make sure the name is sign_in_settings.json.
Make sure the ZIp files which you created are not in folder. I have attached one which i use.
Response Signature
faissal
hello,
i have the same probleme here bellow my files and jason file, i can upload all files and i see changing but not jason file wich doesn't work, i ve used your zip file for test but it doesn't work could you help
thanks, i found the solution for this issue .
