07-09-2017 09:20 PM - edited 03-18-2019 01:16 PM
I'm currently running CMS internally while using Expressway for WebRTC to the outside world and it's working well. At present, Cisco Meeting App/XMPP isn't supported via Expressway and it requires the deployment of CMS edge.
Is it possible to use Expressway for WebRTC, while using CMS Edge for CMA/XMPP? And if so, would the Load Balancer be the only service deployed on CMS edge, as the Webbridge is running on internal CMS and the TURN server is running on Expressway?
Cisco's roadmap is to use Expressway as a single edge for all CMS functions, so I'm trying to deploy as few functions on CMS edge as possible while still getting both WebRTC and CMA functionality.
Solved! Go to Solution.
07-09-2017 10:06 PM
You should be able to use Expressway for web proxy for CMS WebRTC, and CMA at the same time. Since Expressway doesn't support CMA currently, you'd need to deploy TURN on CMS Edge though to support it. Take a look at the TURN section in the Expressway Options with Cisco Meeting Server and/or Microsoft Infrastructure (X8.9.2).
07-09-2017 10:06 PM
07-09-2017 10:08 PM
Thanks Patrick
