Codec c60 access
syper
Hello.
Does anyone know how to factory reset the Codec c60 when there is no access via the web interface and the OSD menu is not displayed on the screen? I have donated the equipment taken over by the tax authorities, but unfortunately, apart from turning it on and off, I cannot use it because I do not have access to the configuration menu.
Firstly, the C60 is a very old and end of support device (since 30 June 2020), so I would suggest you consider using a more modern and supportable device.
But, to answer your question, this question has been asked a number of times before - a quick search of the forums resulted in this thread Factory reset on c60
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
