04-05-2022 11:31 PM
Hello.
Does anyone know how to factory reset the Codec c60 when there is no access via the web interface and the OSD menu is not displayed on the screen? I have donated the equipment taken over by the tax authorities, but unfortunately, apart from turning it on and off, I cannot use it because I do not have access to the configuration menu.
Solved! Go to Solution.
04-12-2022 06:37 PM
Firstly, the C60 is a very old and end of support device (since 30 June 2020), so I would suggest you consider using a more modern and supportable device.
But, to answer your question, this question has been asked a number of times before - a quick search of the forums resulted in this thread Factory reset on c60
Please remember to mark helpful responses and to set your question as answered if appropriate.
04-12-2022 06:37 PM
