Compatibility between Expressway and CUCM
NetExprt
Dears,
we are planning to upgrade expressway to 14.05 knowing that we are running CUCM 12.5
is there any compatibility issue ?
b.winter
The CSR compatibility matrix only gives you a minium and recommended version.
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
But there is no maximum supported version.
To answer your question: No general compatibility issue.
