11-26-2013 02:33 AM - edited 03-18-2019 02:12 AM
Hello, I'd like to know if there is a document somewhere stating which systems could be registered with TMS 13.2.1 and TMS 14, because we were thinking of upgrading the TMS or not, also we had a bunch of systems, old ones too which we're not that sure if can be registered as a system type instead of a Room.
We had this bunch:
Tandberg 1000MXP, 3000MXP, 75MXP, 770MXP, 880MXP, 95MXP, 990MXP, Maestro.
Polycom VSX7000A, Viewstation 128, Viewstation.
Lifesize MX.
I think the MXP series can be registered with no issues, but i'm not sure about the Polycom VSX, Viewstations, Lifesize MX, and Tandberg Maestro (Even if it's still a Tandberg ).
Regards.
Solved! Go to Solution.
11-26-2013 02:53 AM
Here is the document for 13 at least
/Magnus
11-26-2013 02:53 AM
/Magnus
11-26-2013 07:03 AM
All the MXP is fine, including the Maestro since I remember it was based on MXP software. However, it is an EOL product.
As far as the Polycoms you mention, those are supported as well...but not for long...see the TMS 14.3.1 release notes (page 12):
Lifesize has never been supported. They can be added as rooms only.
