Components for Cisco TelePresence Endpoints
denis.moiseenko
Hello!
Could somebody help me with these questions:
Is bracket mounting for PHD Cam (BRKT-PHD-MONITOR=) included in Integrator Package C60 or I need to order it separetly?
Does Cisco TelePresece Touch 8" with cradle and handset (CTS-CTRL-DV8=) compatible with codecs C Series/Profiles or codecs C Series/Profiles only support Touch 8" without hanset (CTS-CTRL-DVC8=)?
Thank you in advance
-Denis
Dharmesh Nandoria
Hi Denis.
(BRKT-PHD-MONITOR=) is not showing in default part list , You can contact Cisco account manager for clerification .
Touch panel is same , EX touch pad is having handset and can be connected directly with coec where C series Touch pad do not have handset and requires external PSU.
So if you connect EX series touch pad with C series codec handset will not work .
https://supportforums.cisco.com/thread/2179316
https://supportforums.cisco.com/thread/2098588
hth
Kind regards,
Dharmmesh
denis.moiseenko
Hello Dharmmesh!
Thank you very much for your help!
-Denis
