CON and Serial Number Issue for Telepresence
Ariq Ibne Aziz
Beginner
Beginner
HI
Im going to purchase the smartnet for the below product.
    Product                         Smartnet                        Qnty
CTS-SX20-PHD12X-K9 CON-ECDN-SX2PHD12 2
CTS-QSC20-MIC CON-ECDN-QSC20MIC 2
As I have to collect the serial numbers of the hardware so I little bit confused about the Serial numbers.
1. For CTS-SX20-PHD12X-K9 which serial number i have to use ? Camera or CODEC ???
2. For Microphone CTS-QSC20-MIC i have got 2 sets of microphone and there are 2 mics for each set. i have found 4 microphones now. So for purchasing the CON, which microphone serial numbers i have to collect ???
THanks in advance. Waiting for a reply.
ARIQ AZIZ
Senior SE. Leads
Patrick Sparkman
In my experience working with SmartNet, it all depends on how the items weee purchased, is: together with a codec or separate. The camera could be covered under the codec's serial number if purchased as a bundle or if the camera was purchased separately, than it would be covered under its own serial number.
The microphone is covered under the codec's serial as it's a minor part to the codec, again this all depends on how these items were purchased to behind with.
You should reach out to a local Cisco partner, they should be able to help with SmartNet and making sure everything is covered like you want.
This is the estimate
v.5 CTS-SX20-PHD12X-K9 SX20 Quick Set HD, NPP, 12xPHDCam, 1 mic, remote cntrl --- 2
  CAB-MIC20-EXT Extension cable for the Performance microphone --- 2
  PWR-CORD-UK-A Pwr Cord UK 1.8m Black YP-61 To YC-12  --- 2
  CTS-QSC20-MIC Performance Microphone 20 --- 2
  LIC-SX20-MS MultiSite Option for SX20 --- 2
  CTS-RMT-TRC5 Remote Control TRC 5 --- 2
  LIC-SX20-PR Premium Resolution Option for SX20 --- 2
  CTS-PHD1080P12XS2+ PrecisionHD Camera 1080p 12x Gen 2  for use in auto expand --- 2
  CTS-QSC20-MIC+ Performance Mic - for auto expand only --- 2
  LIC-SX20-DD Dual Display Option for SX20 --- 2
  BRKT-PHD-MONITOR Bracket mounting for 12x PHDCAM to monitor --- 2
  CAB-HDMI-PHD12XS Custom 12xcamera cable; HDMI, Cont. and Power (3m) --- 2
  CAB-2HDMI-3M HDMI to HDMI cable --- 4
  CTS-SX20CODEC-K9 SX20 Codec - encrypted --- 2
  LIC-S52010-TC-K9 License Key Software Encrypted --- 2
  LIC-SX20 SX20 License Key --- 2
  LIC-SX20-HD High Definition Feature for SX20 --- 2
  LIC-SX20-NPP SX20 Natural Presenter Package (NPP) Option --- 2
  SW-S52010-TC7-K9 SW Image for SX20 and MX200/300 (2nd gen) series endpoints --- 2
CON-ECDN-SX2PHD12 ESS WITH 8X5XNBD SX20 Qk Set HD, NPP, 12xPHDCam,1 mic,RC 36 2
CON-ECDN-QSC20MIC ESS WITH 8X5XNBD Precision Microphone 20 36 2
This is how it was purchased.
I will contact with local partner. but i need to do some self study thats why i asked the question.
SO i belive that the Codec's serial Number will cover everything. right ?
