CONFIG WEBAPP CMS 3.3
Chet Cronin
Level 4
Level 4
I am running CMS version 3.3 and trying to get WEBAPP working.
One thing I noticed reading the Configurating WEB APP CISCO guide is last page when I need to WEB into the CMS.
I go to Configuratio > General  page.
I don't have the "External Access"  Web Bridge URI window under the IVR inforamtion ?
I have the WEBBridge3 certs successfully installed I also have the c2w path correct in the API set.
Chet Cronin
b.winter
everything is done via API.
- You need a new webbridge object, where you put the c2w url (which points to the webbridge component in CMS)
- Add a new empty webbridge profile
- In the new webbridge profile, add a new webBridgeAdress with the parameter "address" set to the meeting url (e.g. https://meeting.cisco.com)
- In the webbridge object, assign the webbridge profile
6 Replies 6
b.winter
Chet Cronin
Level 4
Level 4
I am working off this document :
https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server-1000/216028-how-to-configure-webbridge-3-on-cms.html
Only indicates configuring the webbridges object ?   I entered c2w://bhrncms01.mcw.ad.usmc.smil.mil:9999 for the URL.
Chet Cronin
But the first sentence says, for which version this doc applies:
How do expect it to be the same config then for a different version? You wrote, you have 3.3.
A lot has changed about how to configure CMS, especially in the last 2.9.x and first 3.x versions.
Chet Cronin
Level 4
Level 4
When I was on the cisco site I only saw configure webbridge3 for version 3.0 so I assume it was good for version 3.3 ?
Do you have a link for the doc for version 3.3 ?
Chet Cronin
There aren't always config example or tech notes available for every version.
I don't have such a doc either, but you can always refer to the depyloment guide. There is one for every version.
Chet Cronin
Level 4
Level 4
Got it figured out ... thank you ...
Key was to make sure the certs were good and the fqdn was entered correctly
Chet Cronin
