connect and configure MCU with CUCM
wisam.qazzaz1
hii
what is the benefit when i connect the MCU with CUCM  ?! , and how can i connect and configure MCU with CUCM.
Thanks.
Rajkumar Yadav
Level 4
Level 4
Hi Wisam,
You can refer the below link for better understanding and configuration steps.
https://supportforums.cisco.com/discussion/11587226/registering-mcu-cucm-86
https://supportforums.cisco.com/discussion/11583756/cucm-86-multipoint-calls-tp-endpoints#3715176
http://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/articles/mcu_send_receive_sip_calls_cucm_kb_346.html
If you don't have conductor and only CUCM with MCU then you can achieve the ad hoc video conference facility.
Also for meetme as mentioned in above doc you have to create H323 Trunk pointing to MCU for meet me conference.
Although this is not preferred architecture from Cisco, still you can make it use for adhoc video conference in CUCM environment.
Raaj
[+5] to Raaj
Hi Wisam,
you can also refer the link for deployment guide
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/mcu/install_guide/mcu_deployment_guide_4-5.pdf
http://www.cisco.com/c/en/us/support/conferencing/telepresence-mcu-4500-series/products-installation-guides-list.html
regds,
aman
