Contacts on Telepresence EX90
mmorales1111
Hi, good morning, please someone how i can import or export contacts (favorites) on the EX90?
thobonho2
This can easily be done through the web interface now. Go to https://IP/web/phonebook and you'll find Import and Exports buttons.
Anthony Thomson
Level 3
Level 3
See this thread:
https://supportforums.cisco.com/discussion/11554931/how-backup-local-phonebookfavorite-c-series-or-ex-series-tc50
Note that the reference to logging in as 'root' will only apply if your software version is older than TC7.1.0.  It is permanently disabled after that, for security reasons.  You might get away with downgrading to 7.0 or lower just to get access to root again, but I haven't tried it myself.  Not sure if that will work or not.
mmorales1111
Thanks, your information was valuable.
thobonho2
