05-18-2012
02:38 PM
- last edited on
03-25-2019
09:03 PM
by
ciscomoderator
Where can I find the documentation the describes how to convert a 7985 (T150) from a SCCP load to either an H.323 or (if available?) a SIP load so I can register it to my VCS-C/E instead of just CUCM.
05-18-2012 03:52 PM
You would've been able to do that with just about any other TANDBERG system, but the 7985 (T150) doesn't fall into that category - unless things have changed now that TANDBERG is Cisco see:
http://vtctalk.com/forum/showpost.php?p=72254&postcount=9
/jens
05-18-2012 04:27 PM
How do I tell the difference?
This unit is Tandberg branded/badged, not Cisco.
Am I in luck?
05-18-2012 05:48 PM
Don't know - guess best bet would be to either contact your Cisco rep or open a case with TAC and see if you can get a key for it.
/jens
05-18-2012 06:26 PM
Not sure if it works for the 150mxp, but maybe this document helps you:
How to convert a MXP 1000 with SCCP M2.x Firmware to a MXP 1000 with F9.X Firmware:
https://supportforums.cisco.com/docs/DOC-24414.pdf
Anyhow it would require a valid license key like Jens mentioned.
It might be better then nothing in a lab enviroment, but to be honest, do you really want to use it?
JabberVideo will give you a better quality.
Getting some E20 as long as they are available might be a good idea as well :-)
