Creating users in Jabber video for telepresence (TMSPE)
Louis-Alex
Here's the situation.
Few days ago, I set my provisionned group to NOT import users from the AD.
But it seems that the users are still synchronized with it...
Even after a password change, people have to use the old pwd to sign-in.
Furthermore, I cannot create users on the TMS only... Jabber will not connect if the account is not also created, active AND member of a certain group in the AD (as before when import from it was configured) An other thing is, that the password use by Jabber, will be the one configure on my AD account, no matter if my user on the TMS have one...
Am I missing somethin' ?
18 Replies 18
Hi Louis,
Device provisioning key is a zero dollar item, when you order the VCS-C you include that SKU that's all.
So just check your licensing and you might be haivng the license already. Add it your VCS-C and then setup the provisioning extension replication on VCS-C under TMS.
Alok
That's could be awesome !! :-)
I'll check and come back !
Thnx guys !!!
Ok.
Here's the new scenario.
First, and you said Alok, I found my option key, entered it on my VCS and everything was cool :-)
But now, I can get my VCS to sync with my TMS...It always raise an HTTPException (Response : (400) HTTP Error :) ..
any Ideas ?...
Can you follow this thread and check if it helps you ?
https://supportforums.cisco.com/t5/telepresence/http-exception-after-migrating-tms-with-tmspe/td-p/1955117#3694273
Also i am not sure what version of TMS/TMSPE you are running ? A lot of this dependent on JAVA version you are running. make sure all the components involved starting from Windows OS to Java, everything is compatible with the version you are installing.
Alok
