CTS 3000 over internet using VCSC e VCSEX
Hello to all,
One of our customers currently use:
2 CTS 3000
1 CTS 1300
CUCM
CTS Manager
multipoint Switch
Now he needs to make calls through the Internet.
My questions are:
Can I use a firewall traversal solution with VCSC in the trunk with the CUCM?
If I use this solution a CTS can call another over the Internet?
If it can do this call, the display is the classic with three monitors?
Do I have to use the Telepresence Server to generate the call?
Thanks in advance
Best Regards
Artemisio
sagsheth
Hi Artemisio,
You can use the following setup
CTS>CUCM>>>Sip Trunk>>>VCS-Control>>>VCS-Expressway>>>Internet>>> Endpoint on Internet.
Please note that if you are using 3 screen endpoint, the display will only single screen, because this wont be a TIP negotiated call.
To have better experience, you can use Telepresence Server to host the call and make your CTS and Interet user join the TPS. So the multi-screen experience will be retained.
Sagar
sagsheth
Hi Artemisio,
Sagar
Thank you very much for your reply.
You are welcome..
If you think you question is answered, please rate the answer and mark this question as answered.
Sagar
