CTS 3010 - LCD not detected by System
kllow5115
System shows LCD is not detected via serial. Serial cable connection is according to procedure. What else can I miss ?
samuel.gay
Just to be sure, did you activate LCD in CUCM?
What is the version of your CUCM?
Samuel
5 Replies 5
samuel.gay
Samuel
Why CUCM ? But LCD is connected direct to ACU & indirect t
o Primary Codec.
Yes but you need to activate LCD in the CUCM in the CTS-3010 device that you create.
OK. I will check with person in charge as I dont't have CUCM access.
What about CTSAdmin ? Any activation/ configuration ?
No
