CTS CLI timeout in putty
shaitoledano
hi all
I'm using the CLI in the CTS via putty
the problem is that the window close after 10min if you don't send any command
is anyone know a way to change it?
thanks
shai
Saurabh Gupta
Level 3
Level 3
Hi Shai,
This is by default behaviour of all the CTS Codec that the session would be closed or log off in 10 minutes. There is nothing much you can change about this.
Saurabh
Saurabhs answer sounds point on. I did not find any ssh timeout setting in the command guide.
Anyhow, it might be interesting to check if a ssh client which can send a ssh "noop" would
keep the session alive.
