CTS Edge 95 MXP optional Mic
BSILA OMAR
I want to have an optional Mic for the CTS Edge 95, but I couldn't find the PN of the Mic on the Datasheet of the Edge 95. can some one help me with this.
Thank you for your help.
Omar
Tomonori Taniguchi
PID: CTS-MIC-OMNIDIR=
This is Omni Directional Microphone (AT841UG) includes 7.5m cable
7 Replies 7
Tomonori Taniguchi
Thank you very much.
Omar
Hi Omar,
Please note that the description for the Part is not fully correct. We have been facing issues where the RMA was created for this Part and only Mic was shipped without the 7.5m cable. We have already raised a request to get the description for this part changed.
Hence :
CTS-MIC-DIR=;       is for Directional Microphone
CAB-MIC-7.5M=;     is for Mic Cable 7.5m
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Hi Mubashshir,
Thank you very much for your reply,
I will be ordring those part numbers you sent me.
Omar
Hi Mubashshir,
another thing, since you already raised a request, it will be better if they include these PID in the Datasheet of CTS EDGE 95, 75 MXP, in an optional products table.
Omar
Hi Omar,
We will definitely consider your request and if possible, will be posting these to the document. However, the decision for this needs to be taken from the higher authorities and hence I will not be able to comment if that would be possible.
Mubashshir Akhtar
Tomonori Taniguchi
PID: CTS-MIC-DIR=
This is Directional Microphone (AT871UG) includes 7.5m cable
