CUCM - Expressway-C can't change Media encryption mode
salih.dogan
There was a penetration test at the company and the tester said that  there is a unencrypted traffic between CUCM - Expressway-C. The tester can see user credentials base64 information. So I checked Exp-C zones. I can see "Media encryption mode" is "Force unencrypted" on TCP zone and I can't change that.  I want to encrypt all traffic. I attached screenshot. How can I change that?
hi,
I didn't change Force unencrypted option but after CUCM 11 all traffic encrypted. Here explanation:
In CUCM 11, a new feature was added were we now support encrypted TFTP communication on port 6972 , instead of 6970 .
With this improvement, traffic between C and CUCM on port 6972 will be encrypted and secured. And port 6970 will be used for non-encrypted devices only.
j.huizinga
Level 6
Level 6
hi,
did you ever find a solution?
thanks
JH
hi,
