CUCM version for Spark Room Kit
rfrome
HI, can we confirm that 10.5(2.15111.1) is the release that introduces the device type in CUCM to allow registration?
Jaime Valencia
That information is included in the README, did you go through it?
java
if this helps, please rate
Yes, i read the Readme/Release notes. To call it vague is being more than kind.
Device pack 10.5(2.15111.1) does add support for Spark Room Kits, just as the release notes clearly state:
Add device enablers for Cisco Spark Room Kit and Cisco Spark Room Kit Plus
If you also check the linked bug, it shows an enhancement request for CUCM to add support for Spark Room Kits with device pack 10.5(2.15111.1) for CUCM 10.5.
So is there a Spark Room Device Pack for Cisco CUCM 10.5.2.10000-5?
