CUCM WebeX cloud video conferencing
Hi guys. We are planning to deploy webex cloud based .  I think we  need to create new Region/Device Pool with specific video/audio settings for devices participating to webex conference , correct ? I could not find recommendation about this  in SRND .
What is the best practice ?
Thank you
5 Replies 5
Patrick Sparkman
What you're looking for is the CMR Cloud Enterprise Deployment Guide (WBS31).
2 have 2 big sites , 1 is in UK 2nd in USA . In case of Cisco® Collaboration Meeting Rooms (CMR) Cloud feature both site will be connected to the cloud so  No direct SIP trunk between UK and USA offices , correct ?  So my sip will end on expressway-C and then will be routed in the Internet, right ?
It will look similar to Figure 1 on pg 8 in the deployment guide.
CUCM > Expressway-C > Expressway-E > Internet > CMR Cloud
  ok, I see, we have existing SIP trunks to UK Cisco TMS we still can utilize , I think, and then CUCM or Expressway-C will join UK users to webex meeting . Right ?
As long as the sites can get out to the public internet via your Expressway-C/E, you should be fine.
