CUVC-5110-HD10 - SIP Services Registration Failure
Jim Augherton
     I'm having disconnect issue with Adhoc TelePresence calls - after about nine and half minutes I get an abnormal disconnect error MSG's. and the calls have to be reinitialize.  The call is initiated on my end and it happened with two different locations yesterday.  I'm at a loss where to start looking for info.  On the status page the SIP server has a red X associated with it, just wondering if this may be a factor.  I do have a SIP trunk configured. I'm running code 7.2.0.0.1 on 5110, CCM I'm running 9.0.1, CTMS I'm running 1.8.2, TPM I'm running 1.8.1, VCS I'm running X7.2.1.
Thanks for any help
Jim
Paul Anholt
Hi Jim,
This is a common issue caused by a bug on the CUVC (CSCtl43708) where the CUVC does not properly implement the session expiry value from the UCM side.
The workaround is to disable the session expiry support on the CUVC as shown in the image below:
-Paul
ahmashar
Level 4
Level 4
Hi Jim,
do you have network diagram of your setup?
somthing like:
MCU -- VCS --- CUCM -- CTS
or whatever the case may be.
do all participants get disconnected from the ad-hoc conference after 9.5 min or some?
where the endpoints registered? where MCU is registered? more details required.
regards, Ahmad
Paul Anholt
Hi Jim,
-Paul
Jim Augherton
Thanks for the info - I had TAC this right after posting, and this was the same procedure they used too.  I've made some calls that lasted at least 15-20 each with no problem.  I'm still troubleshooting to be sure if fact that was the only problem.
Jim
