Daisy chaining for 2 PrecisionHD 720p cammera with 1 PrecisionHD 1080p, with codec C90
Rodrigo Moreno
Is it possible to do daisy chaining for 3 cammeras having different resolutions, with codec C90?
Thanks a lot!!
Hi Moreno,
Camera control is using visca protocol , it is same in both cameras .
I have tested previously and it works in lab .
Kind regards,
Dharmmesh
5 Replies 5
Tomonori Taniguchi
Yes, daisy chain only reply the camera control and management signal.
Video directly send from Camera to C90 Codec using HDMI cable and video format configuration is depend on PHD Camera setting and video format setting on each video input on C90 codec.
But isn't there a compatibility issue considering that I'll have in my daisy chain control, different MODELS of PrecisionHD cammeras?
THAKS
Hi Moreno,
Kind regards,
Dharmmesh
There might be limitations, like it can only be one 4x precision hd 1080p cam and it must be last in the chain.
Also with 3rd party products I would do some testing, I could picture different bitrates and vendor specific
protocol "flavors" could cause issues.
Rodrigo Moreno
Thanks Dharmesh, indeed both cameras are using VISCA, so I'm glad to read you've deployed these PrecisionHD cameras with different factory resolutions and they've worked fine!!
