01-31-2013 02:58 PM - edited 03-18-2019 12:31 AM
I know NTP is UTC is UTC is UTC, but is there nowhere within TC5.1.4 to adjust for DST? This is for an EX90.
01-31-2013 06:40 PM
It should automatically adjust for DST depending on which city/area has been selected within a time zone.
I.e. my time zone is GMT +10, and as I'm located in Queensland, I select GMT+10 Brisbane, which gives me correct local time without DST which is Australian Eastern Standard Time (AEST).
If I change this to GMT +10 Sydney etc, DST is added, and time correctly displayed, but this time in Australian Eastern Daylight Saving Time, which is AEST +1hr.
/jens
02-01-2013 08:28 AM
Thanks for the reply Jens. I am in the state of Alabama, which is Central Time GMT -6. I have tried all the different location choices for GMT -6 and they are all the same. At present, these are 1 hour too fast. This is compounded by the strangeness that Mexico City is currently in DST, but yet when I select Mexico City, it's still GMT -6.
02-01-2013 01:39 PM
Sounds like the setting is either not taking - if you change the setting to something in a completely different timezone, does this stick or is it stuck on -6? - or there's a problem with the ntp server, guess you've tried another server? Might want to upgrade to TC5.1.6 as well, you never know...
Edit: Actually, TC6.0 has just been released.
/jens
