08-22-2013 07:26 AM - edited 03-18-2019 01:40 AM
i have an c40 running tc 6.1.1 with 2 cameras connected to it it works fine when i am using the remote control with the unit but when i connect the cisco touch panel and try to present the pc it choses camera as the defult presentation sourse. the web interface says that imput 3 is chosen as the defult presentatin sorce. and even if i change it the camera will still be the defult presentation sorce
Solved! Go to Solution.
08-22-2013 09:39 AM
hi Peter,
Please share the Xconfig Video logs from the codec.
that will give more details.
As at present the default source selection is going on the camera 2 rather than the PC.
if you take off the camera from the codec does it still switches to the camera with a black image (as camera not connected)
Awaiting response
Ravi Kr.
08-22-2013 09:39 AM
hi Peter,
Awaiting response
Ravi Kr.
08-23-2013 08:05 PM
Hi Peter,
You are most likely running into Bug Id CSCue78225 which is resolved in TC6.2.0.
I would recommend upgrading the system to it.
PS
