Dial peer question
Colin Higgins
Level 2
Level 2
I have a dial-peer and translation rule configured on one of my voice gateways that I am confused about.
dial-peer voice 108 voip
description To pla-2k3-ipfx-01
translation-profile outgoing fax
preference 2
destination-pattern XXXXXXXX[3-4][0-5]
progress_ind setup enable 3
voice-class codec 2
voice-class h323 2
session target ipv4:10.6.1.41
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
This dial peer will accept calls to destination pattern number and forward them to our RightFax server at 10.6.1.41. That much is clear.
However, the
is where I am confused.
there is a translation rule/profile 1 with a bunch of translations in it, but what is this command really doing?
Does this mean any number dialing out from 10.6.1.41 is translated when making a call to the PSTN? (we have a PRI connected to the PSTN).
paolo bevilacqua
Voice translation profile and rules indicatet the numbers are changed according to certain rules. You can search cisco.com about that.
ro-mgi-cco
Hy Colin
Can you post the traslation rules?
AHMED Ali
Usually translation done in IOS gateway as per the following:
1. Create translation rule
2. Create translation profile & associate with this rule
3. Apply the translation profile to voice port or dial-peer
In your case, you should see translation profile named FAX which is linked to a translation rule (match for called or calling number depends on the party need translation)
Hope this could help.
Ahmed Rizk
Simerpreet Singh
Hi Colin,
Please refer to the doc
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
In a nutshell, the profiles contains a set of rules which govern how a number will be manipulated based on a set of regular expressions.
Rules work like
/match pattern/ /replace pattern/
a group of rules  are assigned a profile. Paste the profile and associated rules here and we can try to help you.
