Dialing external URI's from CUCM via VCS-C and VCS-E
kseewald
Dear Experts,
how can I make a dial-rule for calls to VCS from CUCM? I mean, I can make a SIP Route Pattern with cisco.com or *.com but
I would need a wildcard for all pattern. I tried to use *.* but this doesn´t work.
Do you have any pattern which is working?
Klaus
10 Replies 10
tunderhi
Hi Klaus
I was told that *.* was a valid SIP route pattern https://supportforums.cisco.com/message/3898336#3898336
I have a setup like yours which I'm just starting to test but I can't see the call hitting the VCS-C.
Cheers
Trevyn
so same to me - I don´t get any entry in VCS-C - so I think that *.* is not working at all - but I can´t
put in all possible domains like  *.com  *.eu *.net  and so on. So if you find a solution it would be very helpfull.
and if I make a pattern like cisco.com it works - also *.com is working
just for information - I use CUCM version: System version: 9.1.1.20000-5
Agreed.  I would like to be able to call any domain name suffix so listing all of them isn't scalable.
just one more question regarding this - when put in a pattern like *.com and this works, it should also work with *.* isn´t it?
Do you have only the pattern *.* or do you have also some other pattern (even if they don´t match)?
ahmashar
Level 4
Level 4
I have test *.* pattern and works fine. I guess you need to review your misconfiguration somewhere else on CUCM. Enable traces and see what you discover in the logs. follow this document very carefully and you shall have a working SIP trunk
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cisco_Unified_Communications_Manager_Deployment_Guide_CUCM_8_9_and_X7-2.pdf
and another one - do you have also *.*.*  for maybe test.co.at ?
you just need *.* which is wild card for everything.
one more thing, I haven't tested for this scenario
*.*.*  for test.co.at
but this *.* worked for test.com.xx
