09-14-2012 05:38 AM - edited 03-17-2019 11:48 PM
Hello all,
I'm playing around a bit with the integration between Cisco CUCM and Cisco VCS.
Internally everything is working fine. I can call from a Cius (registered to CUCM) to an MX200 (registered on VCS) and vice versa.
My question now is, is it possible to dial from this Cius for example to an external video device (device@externaldomain.com) like I would do with my MX200?
I'm coming from the Tandberg business so I'm not yet very familiar with CUCM but as far as I know it's only possible to dial numbers on CUCM right?
Is there a possibility to route every call on CUCM to my VCS infrastructure (which also includes a VCS Expressway)?
09-14-2012 08:08 AM
Hi Peter,
You can use the SIP route pattern on the CUCM for this. Create the SIP domain routes and select the SIP trunk to VCS.
under cucm call routing--> sip route pattern you can define the domains for which you want to send the call through VCS traversal solution.
I have seend this working where customer was using CUPC client to make the calls to other domains. Even Ex90 registered on CUCM can be used for this purpose.
Alok
09-14-2012 08:09 AM
check the link below.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b03siprp.html
09-15-2012 04:08 AM
Hm yes I was also thinking about this.
But then I have to create entries for every domain I want to call?
Basically I want be able to call any domain.
09-15-2012 06:58 AM
You will have to upgrade to CUCM 9.x for that to work to any domain.
09-15-2012 07:42 AM
Hi Peter,
check the link i posted..
Domain name examples:
cisco.com, my-pc.cisco.com, *.com, rtp-ccm[1-5].cisco.com
Valid characters for domain names:
[, -, ., 0-9, A-Z, a-z, *, and ].
IPv4 address examples:
172.18.201.119 or 172.18.201.119/32 (explicit IP host address); 172.18.0.0/16 (IP subnet); 172.18.201.18/21 (IP subnet).
Valid characters for IP addresses
: 0-9, ., and /
I think you should be able to set something like this on CUCM.
*.com, *.in, *.org
although i never tried it.
Alok
09-17-2012 12:55 AM
I just tried with *.externaldomain.be
Seems to be working only half because I'm only able to dial E164 numbers @ domain and not H323 ID's or SIP uri's.
I will try with CUCM9
Any idea if there are demo versions available?
I'm now running a demo version with limited licenses of 8.6.2
I had CUCM9 running in Bèta but these licenses have expired.
07-03-2013 04:12 PM
Easiest to do a SIP route pattern from UCM of *.* which points out your SIP trunk to your VCS.
09-17-2012 01:17 AM
This is something im also interested in seeing working, i have a CUCM V9 lab with phones, Jabber for Windows and Cius registered locally.
I've got a SIP trunk to VCS, and all VCS parameters are configured accordingly to reslove URI calls over the internet using DNS.
The only problem i have, is that i'm unable to get the 'phone' icon when i type a SIP URI of
I guess this seems similar?
09-17-2012 02:47 AM
Hi Simon,
if i am not wrong..you are registering the jabber for windows on cucm as normal extensions.
if yes, then i want to give you this information that jabber for windows still doesn't support the URI dialing. if you put the extension then you will get the option to call.
last i heard is it would be supported by cucm 9.0 but some says 9.1 or etc.
Let me check and give you the needed information.
Alok
09-17-2012 04:00 AM
Alok,
My JforW client registers a DN to CUCM, but it also has a Directory URI of
I may be wrong, but i thought the main aim around version 9, was to accomodate URI dialling?
Peter, i would probably have a chat with your cisco representative, not sure how publically available V9 demos are at the moment.
Cheers, Simon
09-17-2012 04:37 AM
simon,
check this
https://supportforums.cisco.com/thread/2152271
clearly mentioned the format dialing not supported. i don't as of now the cucm ver that will support it.
so let me check and give an update.
09-17-2012 05:29 AM
Alok,
You're right, as per usual
The ability to dial external domains via the VCS architecture is something I’m keen to see!
09-17-2012 04:59 AM
Apparently now you also have to pay for demo/lab licenses according to my Cisco representative... 275$
You can still register for 90-day evaluation versions though.
09-18-2012 06:19 AM
How about IP address dialing?
I was testing with this but I can't get this to work.
So I created a SIP Route Pattern with an IPv4 address of an internal video system but when I try to call that IP address, the call does not get forwarded to the Trunk.
Do I have to do something extra to enable IP address dialing?
