doc to intall TMS
gavin han
i'm been trying to find out good doc for TMS 13.x install but no luck. anyone help pls.
awinter2
Level 7
Level 7
Hi Gavin,
all support documents for our Telepresence products can be found at www.cisco.com/support.
To find the latest version of the 'Cisco TMS Install and Getting Started Guide', search the support page for 'Telepresence Management Suite'.
On the main page for TMS, you can find the document you are looking for in the 'Install and upgrade' section.
Hope this helps,
Andreas
