Does TelePresence C20 Work as Standalone ?
scheikhnajib
Hi All,
Does the TelePresence C20 require any version of CCM to run?
I'm looking for a quick video conference kit between 2 sites and was looking into the Polycom and LifeSize products but found that the C20 is reasonably priced?
Any pre-requisistes other than an IP network between the 2 locations?
Cheers,
Salem.
vivsing2
Hi Salem,
In case of C20, you can use it for direct call, you don't need to register codec to any type of Gatekeeper for making IP call, if IP is reachable.
Just make sure that in Advance configuration->H323->Call Mode to be Direct instead of Gatekeeper.
Vivek
vivsing2
Hi Salem,
Vivek
