DVI connection not working in SX20
giodias01
We have a latest version of firmware. Is it the compatibility why DVI connection not working?
If we use HDMI its working. Please do help.
We running out of time as it is an broadcasting company.
We need to work this within the day.
 For your assistance please.
Thank you
5 Replies 5
Can you check the video input detected under Configuration > Peripherals.
Here you can check if the DVI cable and signal is detected by the codec and give you reason why it is not detected like unsupported video format. What is the video source you are trying to connect on the DVI input? Have you tried using other known working DVI cable?
regards,
Acevirgil
Kindly see attached. For the video source we used is a DVI connector(Source 2).
Yes we did verified that the DVI cable is working when we tried to connect it to a laptop and getting an output. It seems that only it is compatible with HDMI connection only.
Thank you
Have you tried to change the DVI type other than AutoDetect?
regards,
Acevirgil
Teck Chye Tang
hi,
check what is your configuration for this :
xConfiguration Video Input DVI[2] Type: <AutoDetect, Digital, AnalogRGB, AnalogYPbPr>
Just checking what may be obvious to some, but not necessarily to others as you say that the HDMI is working - are you trying to use the DVI as an output?  If so, this will not work, as the DVI is an input connection for sharing content from a DVI source (ie a laptop) to the video conferencing endpoint.
The only video Outputs are the two HDMI connectors.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
