E20 Static IP assignment
almelnikov
Hi all!
I found out the reason why E20 phones are not able to work with static IP address. It works correct if you disable Voice VLAN. This is useful if you do not use the unit as IP-phone and do not have Voice VLAN configured on the switch. Unfortunately I do not have one of them with service contract and I cannot open TAC request.
Saurabh Gupta
Level 3
Level 3
Hi Alexey,
This was one of the known issues which E20 dealt with.
Could you tell me what is your current software version running on E20?
If it is TE 4.1 , then please downgrade it to TE 4.0. This should resolve your problem.
Let me know if you need any other help.
Saurabh
Hi Saurabh. Yes, I`m using 4.1 but I solved the issue by disabling VLAN. My post was some kind of help if anyone would have the issue in future.
ha ha ha...  Yeah Alex... We know that... That's y I wrote Its a common known Issue...
This was discovered 2 years back..
in TE 4.0 , you won't have to disable Voice VLAN as well.
I think this issue is also resolved in TE 4.1.2
Cisco Guys, Can you confirm?
//Saurabh
The issue is not resolved in the last firmware. I found the solution to roll back in 4.0, set static IP and then upgrdae back to 4.1. So I decided to show another solution I found out
