06-18-2013 03:52 PM - edited 03-18-2019 01:19 AM
I have a Cisco 4505 MCU and several endpoints. Is there a way to allow my endpoint(s) make an adhoc multipoint call using the 4505 MCU? For example, I would say dial site1 using mcu, then dial site2 using mcu or call a group (site 1 and site1...) using mcu and it would know that is is supposed to use the 4505.
Ravi
Solved! Go to Solution.
06-18-2013 04:03 PM
Sure, you can configure (a couple of 100) static meeting rooms, auto create conferences on the fly based on one template or have both ways set up and there is even an on screen menu users can use to create or join conferences.
Check out the admin guide for example (page 37ff)
06-18-2013 04:03 PM
