EX 90 and Unity Connection
tconnorbok
I am trying to use Unity Connection with the EX90 system. Has anyone been able to connect the two systems and get MWI to work?  I found some documentation but it looks like you need TelePresence to make it work, is that correct?
Paula Talamo
Hello Travis,
This may be the document you are referring to but it details the components and versions needed to integrate Cisco Unity with TelePresence VCS endpoints: http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_CUC_Voicemail_Integration_Deployment_Guide_X6.pdf
Paula
I was wondering if there was another way to do this because we don't actually have the Cisco TMS software which appears to be required in this doc.
