EX90 Endpoint Not Registering through Collaboration edge
Siva chinap
Level 5
Level 5
Dear All,
I am facing issue in registering EX90 endpoint through collaboration edge. Ex90 is unable to register from outside. The status shows un regiter in touch panel . But when i make a outgoing calls its working . I am unable to identify the issue.
I didnt uploaded the security ceritifcate in the endpoint and CUCM is non secure mode.
Below are the confgiuration :
  1. In the TC-based endpoint, select Configuration > Network a
    1. Domain Name:tp.local
    2. Server Address:expe.tp.local
  2. In the TC-based endpoint, select Configuration > Provisioning a
    1. LoginName - as defined in CUCM-->(Owner user id and password)
    2. Mode - Edge
    3. Password - as defined in CUCM--->-->(Owner user id and password)
      External Manager
    4. Address - expe.tp.local
    5. Domain - tp.local
Ex90 endpoint configuration:
Siva chinap
Level 5
Level 5
I registered the endpoint after uploading the certificate.
Below is summary of configuration:
###  We uploaded  the internal root CA to the EX 90 endpoint to validate its server.
### Since our cluster is non secure mode created a Phone Security profile TCP+UDP
1)I need to  know what protocol need to use external manager http or https?
Jaime Valencia
If your CUCM is NOT in mixed mode, why are you using a profile that asks for TLS for the device as if it was in secure mode???
And MRA depends on you having the _collab-edge SRV in the public DNS for it to be found, I don't believe anyone will register a .local domain in a public DNS, for you to get the SRV.
java
if this helps, please rate
Alok Jaiswal
Level 4
Level 4
Have you read about it here.
https://www.cisco.com/c/en/us/support/docs/unified-communications/expressway/118696-config-cucm-00.html
You only use secure profile if you have the CUCM in mixed mode and you want to use encrypted profile. Also make sure that Exp-C certificate must have the secure profile name added as SAN entry and the Exp-E certificate must contain the "collab-edge.domain" entry.
Also as pointed by Jaime, "tp.local" the domain must be externally resolvable. Endpoint registration over MRA is not same as Jabber, in Jabber you can use a workaround as "voice service domain". However it will not work for endpoint registration.
Alok
Siva chinap
Level 5
Level 5
