export device profiles incl. MAC address from CUCM 8.6.2
cristinapetre
Hi all,
is there a possibility to export all device profiles including the MAC address which you can reach through the dependency records? The scope is to get the MAC address which is related to the device profile at the moment.
I didnt find anything therefore the question.
Many thanks in advance.
cu, cristina
Aaron Harrison
Hi Cristina
You can run this from the server CLI - log the SSH session to text, then you can import to Excel!
run sql select e.userid,d.name,dp.name from extensionmobilitydynamic emd join device d  on d.pkid = emd.fkdevice join device dp on dp.pkid = emd.fkdevice_currentloginprofile join enduser e on e.pkid = emd.fkenduser
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Hi Cristina
Aaron
thanks Aaron ;-)
You're welcome!
aarono do yo also know the command for cucm 11.5 ? Its not working...
The specified table (device) is not in the database.
admin:
