Expressway C does not have a "Configurations" Tab
Gura24
i just want to configure the Hybrid Call Service on Ecpressway C but there is no "Configurations" Tab on the GUI!
Is that a bug or the customer did something wrong with the installation? Is it possible to activate the configurations tab?
Thank you!
Cheers
I found the issue. If you choose "Spark Hybrid Call Service" - tick, then the Configurations tab disappears.
Does it have an Expressway release key and option key?
Thanks for quick response!
I thought the same, but in Cisco`s deployment Guide I read the following sentence:
You do not require a release key, or an Expressway series key, to use the virtual Expressway-C for Cisco Webex Hybrid Services. You may see an alarm about the release key. You can acknowledge it to remove it from the interface.
