Expressway CPL script - is a "reject status" required ?
bvanbenschoten
Level 5
Level 5
consider a typical rule to block common SIP scanning
<taa:rule unauthenticated-origin="(.+)@1.1.1.1" destination="(.*)"><reject status="403"/></taa:rule>
is is required that the Expressway send back a reject reason ?
can the message just be silently dropped ?
You must have a status, otherwise Expressway will fail to load the CPL and raise an alarm.
Patrick Sparkman
You need to ether a Proxy or Reject, if you don't have one, that node within the CPL will never take affect.
Can you have a Reject without sending a status message back ?
Such as:
<taa:rule unauthenticated-origin="(.+)@1.1.1.1" destination="(.*)"><reject status=""/></taa:rule>
OR
<taa:rule unauthenticated-origin="(.+)@1.1.1.1" destination="(.*)"><reject/></taa:rule>
Jonathan Schulenberg
One of the CLUS presentations last year on Expressway suggested an IPS in front of Expressway-E if you want a true stealth non-response.
