09-13-2016 07:36 PM - edited 03-18-2019 06:22 AM
Hi ,
I tried to enable IP dialing (option 1) (IP@ vcs.domin) , but still the expressway C forwards the complete sip URI instead the IP. Expressway doesn't strip the domain
Created the transform as shown here.
Pattern String: (.*)\.(.*)\.(.*)\.(.*)@vcs.domain
Replace String: \1.\2.\3.\4
09-13-2016 09:37 PM
Did you test the pattern using the tool within the VCS?
09-16-2016 07:22 PM
I added the above transform to expressway E . Now I can do the IP dialling. But i cant dial polycom because it has Public IP##701224360
I also need to connect external Tandberg devic & its format is name@public IP & still i cant find the way to access these devices.
Let me know , if you have any idea.
Suchi
09-16-2016 07:33 PM
IP##alias is a Polycom proprietary dialing scheme, you need to use alias@IP instead.
To dial alias@IP where the IP is an address of an endpoint on the public internet, you should use Option 2 within the guide you linked to in your original post.
09-14-2016 06:08 AM
Can you provide a screenshot of the transform on the Expressway-C, maybe you don't have it configured correct.
