External Phone Number Mask stops out bound calls
gfremgen
Fairly easy question I assume ut I need to know why adding an external phone number would would stop outbound calls. It is an H323 gateway with a PRI, 4 digit DNs (6000-6999) and when we add 716422XXXX the users can not make outbound calls. Any ideas are appreciated.
No additional dial peer required. If you are only changing the mask, it is almost certainly being blocked by the carrier. Try "debug isdn q931" and look at the diconnect cause code. The following link should help.
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
Brandon
Brandon Buffin
Check with your carrier. It could be that they are blocking the sending of specific outbound caller ID.
Hope this helps.
Brandon
gfremgen
That was my thought at first that the carrier was blocking this, would I get a certain display in debug if the carrier was blocking the number. It is an h323 gatewat and the only thing I do different is add a mask. A co-worker thought that I would need a dial peer that matches the mask, I assume this is not true?
Brandon
