Extra mics on MX700
sakhamuzihadebe
I inherited a Cisco Telepresence setup which came with two standard microphones. I would like to add extra mics to cover the whole lab room. Is this possible? If yes, what do I need to procure?
Jonathan Schulenberg
Sure it is, just check the data sheet which says it has eight mic inputs.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-microphones/datasheet-c78-736073.html
It can use the Cisco table or ceiling mic.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/microphone/installation_guide/ceiling-microphone-installation-guide.pdf
Another very popular mic right now is the Sennheiser TCC2; however, if you want the LEDs to sync/reflect the codec mute state you will need an external control processor, eg Crestron or similar. Probably best to pull in an A/V partner for that.
https://en-us.sennheiser.com/tcc2
