I inherited a Cisco Telepresence setup which came with two standard microphones. I would like to add extra mics to cover the whole lab room. Is this possible? If yes, what do I need to procure?
Another very popular mic right now is the Sennheiser TCC2; however, if you want the LEDs to sync/reflect the codec mute state you will need an external control processor, eg Crestron or similar. Probably best to pull in an A/V partner for that.
