Force Peripheral updates in room series codecs?
Bobby McGonigle
I'm having issues with the Cisco Quad Camera in relation to it's updates, as well as some p60 cameras in ce9.1.x, ce9.2.x, and ce9.3.x.
For a lot of SRK+ units I've acquired, the quad camera and codec plus have been on separate software versions. Some of which, "refuse" to upgrade the camera once connected.
The P60 just needs a simple power cycle and this usually triggers the upgrade.
With the quad camera, it's another story. I've attempted the following:
-Power cycle the quad camera; does not resolve
-Power cycle both codec plus and quad camera in tandem; does not resolve
-Factory reset the quad camera; does not resolve
-Factory reset the codec plus and quad camera in tandem; does not resolve
-Match software version of the codec plus to the effected quad camera, then upgrade to desired software; resolves in some, but not all instances
-Connected affected quad camera to a different codec plus or sx80 system and repeat; same results, no definitive "end-all, be-all" resolution
(All updates I've pushed have either been sent to the unit via TMS[15.5.0] or my machine directly, both yield the same outcome)
I was wondering if anyone knows of an xAPI command to the codec to trigger a peripheral (in this case a camera) to perform its upgrade cycle? I've checked the xAPI commands for 9.1/9.2/9.3 and I can't find one that may help.
Or
If they have a workaround to get the quad camera to upgrade other than the attempts I mention above.
I haven't attempted cisco TAC as of yet for their solution as of yet, but if this is going to continue as it has up to ce9.3.x, I'd much rather a solution I can implement on myself if at all possible.
Bobby McGonigle
(He, Him, His, Himself)
Video Services Engineer, EU Svcs Communication & Collaboration Services
Bobby McGonigle
Solution found.
Downgrade to cameras matching software with ".loads" file rather than ".pkg" and upgrade in the same manner.
Bobby McGonigle
Bobby McGonigle
Solution found.
Bobby McGonigle
I'm having the same issue: can you tell us how you upgrade the codec with the .loads file?  Does this have to be done through CUCM?
Hopefully this will answer your question (or for those that will have it ) as I ran into the same...
1) Installed the Collaboration Endpoint Software bundle in CUCM TFTP nodes, which included the firmware for different types of codecs, which is what I needed.
Example: cmterm-ce9_14_7-6e216653a72.k3.cop.sgn
2) Once installed the bundle, in addition to the pkg firmware files, I noticed that there is a "generic" .loads files in the TFTP server:
07 May,2021 11:20:19 337,517,344 s52010ce9_14_7-6e216653a72.pkg
07 May,2021 11:20:20 546,161,775 s52020ce9_14_7-6e216653a72.pkg
07 May,2021 11:20:20 194,503,463 bifrostce9_14_7-6e216653a72.pkg
07 May,2021 11:20:21 42,484,685 halleyce9_14_7-6e216653a72.pkg
07 May,2021 11:20:21 18,988,171 moodyce9_14_7-6e216653a72.pkg
07 May,2021 11:20:21 113,530,372 pyramidce9_14_7-6e216653a72.pkg
07 May,2021 11:20:21 318,575,124 s52030ce9_14_7-6e216653a72.pkg
07 May,2021 11:20:22 831,344,216 s53200ce9_14_7-6e216653a72.pkg
07 May,2021 11:20:22 209,963,871 s52040ce9_14_7-6e216653a72.pkg
07 May,2021 11:20:23 817,130,485 s53300ce9_14_7-6e216653a72.pkg
07 May,2021 11:20:31 5,921 ce9_14_7-6e216653a72.loads  <<<--- THIS FILE
07 May,2021 11:20:33 256 ce9_14_7-6e216653a72.loads.sgn
3) If you open/view this file from UCM TFTP CLI, you'll notice that it looks like a JSON file that includes the firmware/drivers needed for all types of supported codecs... See example below:
"product": "s52010",
"packageLocation": "s52010ce9_14_7-6e216653a72.pkg",
"version": "ce9.14.7 6e216653a72 2021-05-07",
"targets": [
"101790-2",
"101790-3",
"101790-4",
"101790-5",
"102330-0",
"102330-1",
"102330-2",
"102331-0",
"102331-1",
"102331-2"
"checksum": "621286b44e65b4bef85a3105f90a5c2e491af87d1c25e03df841029daa765c38578c882634f39ee6e910d58c5ca74f603b1a44cd20ad7d470b942654c9ba43f3"
"product": "Bifrost",
"packageLocation": "bifrostce9_14_7-6e216653a72.pkg",
"targets": [
"73-102038-0",
"73-102038-0-dev",
"73-101864-0",
"73-101864-0-dev",
"73-101864-1",
"73-101864-1-dev"
"checksum": "9fbdbd55d393cc3502c48473d5f9e151d89f5b2d79550a4a8cf430362b14d818d985d19c1f3195b9174cd08ac695dda2f54801efbf68c3323c1c268a86f36205"
"product": "s52020",
"packageLocation": "s52020ce9_14_7-6e216653a72.pkg",
"targets": [
"101730-0"
"checksum": "fb48f878d34efcfd46a53ba60c71bec9ac41e34ee3d60409ebe31963b24bd7801336df614bf0b26925d0842b475fc7f5c92e856a1e18e8d4b66be0fbe591782c"
"product": "s52030",
"packageLocation": "s52030ce9_14_7-6e216653a72.pkg",
"targets": [
"100183-0",
"100183-1",
"100183-2",
"100183-3"
"checksum": "ee7f00eccac76065c381ec127df1efbd2b8a741a6abf134322d5dca78b5759349fb409c6b98b330fae34bc842e41c2effe92a547f3d8be41704f9a27ec783f95"
4) So when upgrading your device, instead of telling it to use the .pkg firmware (example: s52010ce9_14_7-6e216653a72.pkg, have it point to ce9_14_7-6e216653a72.loads and the device will parse the file and download the firmware/files that it needs.
