Gatekeeper Restart unexpectedly
Dear Sir,
I have two Gatekeeper in our network, when i check system information, the Gatekeeper has been restarted unexpectedly.
and i have another error log in eventlog,
Sep 21 08:03:46 TSEL-GK1 syslog.err syslogd: unable to start remote syslog: cannot resolve remote server address: server_address
Sep 21 08:03:46 TSEL-GK1 syslog.info syslogd started
Sep 21 08:03:47 TSEL-GK1 local0.notice root: Event="System Start" Level=1 Time=2012/09/21-01:03:47
Sep 21 08:03:52 TSEL-GK1 auth.err sshd[943]: error: Bind to port 22 on fe80::210:f3ff:fe0f:8a02 failed: Invalid argument.
Sep 21 08:03:52 TSEL-GK1 auth.info sshd[943]: Server listening on 10.2.156.6 port 22.
Sep 21 08:03:53 TSEL-GK1 local0.notice gk: Event="Application Start" Detail="Product:TANDBERG Gatekeeper SoftwareVersion:N5.2 SoftwareDate:2007-06-22 BuildId:117996" Level=1 Time=2012-09/21 01:03:53
Sep 21 01:04:07 TSEL-GK1 daemon.info init: Starting pid 1081, console /dev/console: '/sbin/getty'
Sep 21 01:04:07 TSEL-GK1 daemon.info init: Starting pid 1082, console /dev/console: '/sbin/getty'
I need help about the means of this log, Thankyou before.
Thanks&Gbu
6 Replies 6
gubadman
Level 3
Level 3
There's not a lot to go on there really. It just looks like the syslog and ssh deamons are starting and then the gatekeeper software itself starts up.
But that is a really old software version - I'd recommend upgrading to N6.3
Guy
Dear Mr Guy Badman.
Oke Sir, i see.
Thanks for ur Attention,and then how can i get that software sir ?
Can you give me any reference sir ?
Thankyou sir,
Best Regards,
You can get the software from here - http://ftp.tandberg.com/pub/software/gatekeeper/
You'll need a release key to go from N5 to N6 - you should talk to your Cisco account manager or Partner about that.
Guy
Ok mr Guy,
Thanks for ur information.
Best Regards,
Nanda
If this GK has valid service contract, N6 release key for software upgrade can be get from either…,
  1. Contact Cisco License Team (license@cisco.com) with your Endpoint Serial Number and service contract information.
  2. Check license from on-line tool, http://www.cisco.com/go/license.
Hi Mr Tomnig
Okay, i will contact our AM for this.
Best Regards,
Nanda
