Gen1 Audio Science Mics
Anthony T
Level 5
Level 5
If a customer has Gen1 Audio Science mics, with the XLR connector:
  1. Would Cisco part "CAB-XLR-EUROBLOCK=" allow that mic to be connected to the SX80 codec without any further complications?
  2. Is there a part number that would allow it to be connected to a Room/Room+ codec? If not, what would it take to wire it in?
Thanks.
Wayne DeNardi
You should be able to use a standard XLR to Phoenix/Euroblock adaptor (or you can re-wire the mic current mic cables to the euroblock directly).  You can buy these adaptor cables on-line if you don't want to make them yourself.
The pinout would be:
XLR pin 1 to Euro Block Ground and Cable Shield
XLR pin 2 to Euro Block Positive
XLR pin 3 to Euro Block Negative
You can't connect one of these directly to a SX20 or a RoomKit / RoomKit Plus endpoint, there are a few different ways to do this (none of which are officially supported).  You can see some of the ways in this thread: Cisco audio science ceiling mic and SX20
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Okay; thanks Wayne.
