Get CallID from a SIP Call
Av3ry
I am ungodly new at this, so bear with me:
I'm using Cisco xAPI to initiate a call into our Zoom meeting SIP number with the Dial command.
After that call is initiated, I would like to retrieve the CallID from that call in order to pass it into other functions (ex. the xAPI command DTMFSend to send the meeting passcode via dialtone).
How would I grab the CallID?
As your question relates to use of API I would suggest that you ask your question on DevNet as that’s a better place to ask that line of question.
Response Signature
Hi.
While the call is connected the command xstatus call status gives you the call ID:
xstatus Call Status
*s Call 27 Status: Connected
** end
Hope This Helps
Carlo
Please rate all helpful posts "The more you help the more you learn"
