09-16-2013 01:56 AM - edited 03-18-2019 01:48 AM
I am experiencing this kind of issue:
If endpoint-1 with public IP 122.x.x.x will dial "411@company.com" using H323 it was successful.
If endpoint-2 is behind firewall will dial "411@company.com" using H323 call will fail
On the endpoint the message says "unable to setup encrypted call, turn off encryption"
Same settings wasconfigured on endpoint-1 and endpoint-2. The only difference is the network parameters, endpoint-1 on public while endpoint-2 on private behind firewall.
I think this is a firewall issue, what should we check on the firewall for a H323 endpoint to dial the " 411@company.com" address format?
Thank you for help..
Br,
Acevirgil
09-16-2013 02:11 AM
Firstly, the address is not SIP format per see, it is H.323 Annex O URI format, but yes, SIP URIs look the same as well.
What kind of end-points are these, and which software version do they run?
What jumps out at me is this "endpoint-2 on private behind firewall" - so, NAT'ed with other words - in which case you would have to set up a public address and use a static route between the private and the public address, or register the system with a VCS-E or something similar. Remember, the private address is not routable on the internet.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
09-16-2013 02:29 AM
Hi Jens,
Thank you for your response.
The endpoint-2 is NAT'ed. Could you provide list of specific firewall ports needed to make it work?
Thank you for help.
Br,
Acevirgil
09-16-2013 02:51 AM
Well, then it either needs to register with something like a VCS-E, or the end-point you are calling needs to be behind a VCS-E/VCS-S type of set-up and your endpoint needs to be H.460.18/19 compliant.
If none of that applies, then you need to give it a public address and do that static route between the private and the public address, or if applicable use the NAT settings in the end-point.
Since you haven't said what kind of end-point this is, this gives you ports for MXPs and C-series;
https://supportforums.cisco.com/thread/2154000
There's also this doc:
https://supportforums.cisco.com/docs/DOC-18565
This Whitepaper might also be of interest;
http://www.cisco.com/en/US/docs/telepresence/endpoint/mxp-series/white_papers/tandberg_h323.pdf
/jens
