Hi, Anyone knows if I can get phonebook working at MX200 without TMS?
alones123
We have VCS-C and VCS-E only, no CUCM and TMS, just want to know if we can make phonebook working at MX200 or 300.
Kevin
Magnus Ohm
Hi, you can create up 100 or so entries in the local phonebook. Then you can copy the pb file across to the other endpoints but without the tms you wont get the corporate phonebook. And the local phonebook is a manual pr endpoint work. If you want a more flexible solutiom you should aquire the tms
/Magnus
7 Replies 7
Magnus Ohm
/Magnus
Thanks Magnus.
How can I get the pb file from C40?
Pb.xml file is located in "config" folder . log in to codec by winscp using root user and copy the file .
You can paste same file using winscp to other EP .
Kind regards,
Dharmmesh
Thanks man!!
Magnus: Is there a API description to make your own phonebook server?
Magnus Ohm
Hi Martin
Not that i know of, but i doubt it. I never heard of it at least.
/Magnus
The only TMS API that we publically and externally support is the Booking API. And trying to create your own PB server in replacement to TMS wouldn't be a trivial task either And c'mon guys, one of the main and nicest features of the TMS are the Corporate PBs
